74LS244 Question
falter
Vancouver, BC
Assuming that pin 1 stays high, it should be possible to "feed through" pin 8 to pin 12. But the solution ultimately will be figuring out why pin 1 stays high.
Yeah that is is the goal for sure. I just want to prove out my theory a bit. After the experience with the TVT I don't trust schematics or circuit descriptions 100%. I did try feeding through but didn't see any text appear... although I didnt type anything so maybe it would only change new text being added. I'm going to investigate the 7432 attached to that pin and see if the signals are lining up as they should be or if something there or further up the chain is stuck high.
