Wawavoun
Good morning,
Quite suddenly (after formatting and a reinstallation of dos 6.22) my pc 80286 gives memory errors.
The message is:
ON BOARD PARITY ERROR
ADDR(HEX) = (1000:2DF8)
HALTED SYSTEM
It's written in big letters. I think the message comes from the bios. CtrlAltDelete no longer gives anything, I have to use the bp reset.
I also see sometime 1000:2DF2 address.
There is only one application which causes the problem: it appears when launching an ftp transfer (with Mr. Brutman's MTCP ftp) just after the return which follows the get command.
With some small transfer (say file size < ~100 ko) sometime it works at least for the first transfer.
Usually the second transfer fail.
Also with bigger file size the error come every time.
MTCP dhcp or ping are working well.
The boot bios memory test passes well and the 3C509B network card passes the 3Com tests.
Before the new installation, FTP transfers worked perfectly.
No other apps seem to have a problem.
I run several times Checkit 3.0 memory test in deep test mode and he dont report any problem with the memory....
I try different configurations : with and without the packed driver, with and without the RJ45 cable connected and so on with always the same result, no memory problem.
My questions :
- Can msdos, a driver or an application (in fact software) create this kind of problem or is it solely and exclusively hardware ?
- I know it could be a nmi related problem, how can I check that ?
- Your opinions on the problem ?
Thank you, best regards.
Philippe
The message is:
HALTED SYSTEM
My questions :
Philippe
