Druid6900
Ok, I have a decked out Apple II+ case with Sup R Mod, back-mount joy-stick plug and a higher-end memory, a Multi-plex Tech 80 column card (with composite and cable outputs), grappler+ card and Modem80 card.
Now, the board that originally came in it was the 0001-04 and it tests fine. However, I have a loose 0044-C board (which also tests fine) that is more in keeping with the Apple II+ (although I know they used the 0001-04 boards in some of the early II+ system).
Would I be better off (from a seller point of view) to put the 0044-C in the case and sell the 0001-04 board off on it's own, the other way around or would it not matter much at all?
Any opinions would be welcome.
