dave_m
@Giobi:
Try this:
- Insert your adapter with the 2764 into the 8032's A socket (UD11) with all pins connected.
- Turn on the 8032 and type:
S=0:FOR X = 10*4096 to X+4095:S=S+PEEK(X):NEXT: ? S
After a few seconds it should give you a total of 485835.
If you like, lift pin 21 of the adapter or pin 23 of the 2764, connect it to GND (pin 12 or 14) and run the above again.
This time you should get 477492.
Mike,
Is pin 21 of the 2364 the A12 address line? If so then shouldn't we be lifting and grounding pin 2 of the 2764 rather than pin 23 (A11)? I'll admit I am not familiar with the adapters being used.
