NeXT
I owned a 5200 once. It was a dreadful system even with 64mb ram and the Video/MPEG decoder cards. 8.1 was also even worse on it. The bus really does slow everything down.
I would only recommend your system as a stepping stone. It will drive you nuts how sluggish that design was.
You can't brick a mac that old through key shortcuts. If you want to try booting with extensions off you hold down the shift key. If you want to tell the system to boot off the CD you hold down the C key or at least, that's the appropriate key on the Mainstreet Powerbook.I wouldn't want to brick my computer accidentally.
