Since my 'Wanted' thread about a Socket 3 motherboard kind of turned into a support thread for a motherboard I already had that I thought was broken, I thought I'd finally start a new thread and continue posting about it here. There doesn't seem to be any full documentation for this board out on the Internet, although the most helpful resource so far has been this page:
http://museum.ttrk.ee/th99/m/A-B/32472.htm
First things first: Now that it's working and I've made some effort to hook things up to it, it looks like this thing is loaded with nonstandard pinouts!
First, here's what I discovered about the hard drive LED connector. The pinout ended up looking like this:
Seems standard enough, to me, just double the pins it needs, is all. Hooking an LED up straight to the positive and negative pins makes it light up when there is hard drive activity. The positive lines are connected to +5V via 150 Ohms, and the negative lines are switched to ground during hard drive activity.
The real problem was the front panel LED connector. This is what I arrived at after a lot of measurement and experimentation:
This connector required me to do a lot of wire splicing on the front panel connectors of my case. The +5V pin has no current limiting resistor on it. It's wired straight up to the power supply. You can use it to run the Power LED, but you need to put your own current-limiting resistor in place. I accidentally burned out the power LED in my case because I connected it without checking this first. Luckily, indicator LEDs are cheap, so it doesn't really matter. The TURBO pin switches between 5V and GND depending on whether the computer is running in high speed or low speed mode. In low speed mode, the pin presents a HIGH logic signal, and in high speed mode the pin presents a LOW logic signal. I hooked my turbo LED up between the +5V pin and this pin so it will light up when the computer is in high speed mode. The GND pin is exactly what it says it is, a connection to ground. The keylock pins do exactly what they say they do as well. If you short them together, the computer boots normally, but if you leave them disconnected the computer will refuse to boot. There is a two-pin DIS-LOCK jumper elsewhere on the board that is directly connected to these two pins. If it is shorted together, the computer will always be unlocked regardless of the state of the keylock pins on the 8-pin header. The RESET pin has approximately 3.3V on it and resets the computer when it is shorted to ground. There is no pin at position 6 (I assume this was the KEY pin for the original connector) and I have absolutely no idea what pin 5 does.
The IDE and FDD headers on this board are standard pinouts, and I can only assume the 50-pin SCSI header is a standard pinout as well (I don't have any working drives I can test it with). I haven't been able to test anything regarding the COM and LPT headers yet. I suspect the COM 1 header is a standard pinout. It's a 10-pin header with 9 pins available. If it's anything like other 9-pin serial headers I've seen, the 5-pin row would be connected pin-for-pin to the top 5 pins of the serial port and the 4-pin row would be connected pin-for-pin to the bottom 4 pins of the serial port. COM 2, I'm not so sure about. It's a 16-pin header with 15 pins available. I suspect it's meant for a 25-pin serial port, but am unsure how it would be wired up. I'm also not sure about the LPT header. Most computers use a 26-pin header with one pin missing, but this one uses a 20-pin header. If anyone has any ideas for relatively painless ways to get the proper pinouts for the COM 2 and LPT headers, I'm all ears! I'll post all info here once I've figured it out, as this board could really use some better documentation posted online.
