Hi All,
need some assistance here, looked over at ADTpro sourceforge forum and i didnt find the answer to my question. That said, i want to know if there is a way to exclusively transfer a disk image (ie: 2mg, dsk shk) using ADtpro send command and ultimately have it reside to a HD partition sub directory? I have initially tried with a 2mg image but all it did was give me a 'mismatch capacity' and ultimately wrote over the entire 32mb partition (which holds my system 6.0.1 boot). The only way i am currently doing it is by using the original method (PC to 3.5 floppy) then using COPYIIPLUS to create sub directory in HD partition and copy all files on the 3.5 to the desired sub-directory. This way is time consuming and i basically want to eliminate the 3.5 floppy altogether. Anybody have some suggestions?
Also, i just installed 'Trans Prog III' to launch programs in system 6.0.1 (similar to windows start menu), i must be doing something wrong but i cant seem to put any programs in the tran prog start menu, any tips would be appreciated on this as well.
thanks in advance!
thanks in advance!
