Hi everyone, I'm new here but I am getting quite interested in vintage computing and thought I could tap your expertise.
I am considering options for collecting vintage computers (currently proud owner of a C64 and an MSX2) and I think my next machine will be an Amiga of some sort.
I am mainly going to use it for gaming, but I want also to explore other software, I am appreciating the history and peculiarities of these old machines.
I am drawn at first to the Amiga 1200 because of its more powerful chipset and also because it has a HDD port (so I can install WHDLoader) plus I can upgrade its RAM to 8MB. All good.
However, it can be quite pricey on eBay (at least £100 for the unit by itself) and on closer inspection RAM upgrades look less than straightforward, and if the 1200-exclusive software is less than stellar it may not be worth the extra cost (although it would definitely be a prestige item!)
So can anyone recommend the Amiga 600 as an alternative? It appears to be similar to the 1200 in every way bar an older chipset and no numerical keypad. However, it still has a HDD port and upgradable RAM, albeit it won't play 1200-exclusive software.
Thoughts on either? And is upgrading the RAM a tricky job - I see pictures of the trapdoor under the 1200 and it looks like it's not as simply as slotting the RAM into conveniently-positioned slots, but a matter of opening up the machine and adding new boards/soldering, is that correct?
Is there a decent online guide for RAM upgrades anywhere?
Many thanks for your comments
