I've got a 386DX/40, which was working fine with AHA-1520B (non-bus-master, DMA disabled) and Pro Audio Spectrum 16.
But I've replaced the SCSI host adapter with AHA-1542CF (bus-master, needs DMA).
Seemed to work great, disk throughput increased by 40%.
But then I tried to play some music - WAV files using PLAYFILE, and MOD files using Inertia Player - and it turned out that simultaneous sound playing and disk activity is impossible, the sound just stops.
It can't be typical resource conflict:
AHA-1542CF is set to 130h, IRQ 11, DMA 6
PAS16 is set to 388h, IRQ 7, DMA 5 (and 220h/5/1 for SB emulation, though only using native software here)
Changing AHA-1542CF DMA channel to 0 helps a little - the sound doesn't stop at once, but distortions can still be heard.
Also, disk throughput is a little slower - obviously because DMA 0 is 8-bit.
Any idea what's going on?
Are there any known issues with AHA-1542CF?
I thought it was the best ISA SCSI host adapter ever, but now I'm thinking about going back to AHA-1520B...
