Micropolis says a 146Mb. SCSI (https://www.micropolis.com/support/hard-drives/1375)
the SCSI2SD should boot or sub just fine with the proper image.
Thanks, I suspected the '11' was something like that. I'm still in Alaska for a couple weeks, but the am1200 had been inside (low 70's) a few days so it was pretty warm.mike,
DIAG 11 comes from the execution of TRMDEF when no terminal driver (.tdv) is found. ^c issue sound like a :R .INI. Due to the one boot only, it sounds like a disk error affecting boot.TDV, was that testing done in Florida or Alaska, I’m curious if that was a cold (as in temperature) drive when you booted it?
I wouldn’t send the drive away just yet, if you get the 1200 running on a SCSI2SD or the like, you could just setup up the Quantum as a SUB: DSKANA the SUB: the DSKDDT any errors, may not fix it, but if it did it would be a cheap and easy fix. The ^c fix is also easy, just remove the AlphaBase launch from AMOSL.INI.
Don’t know anything about the Zulu but maybe jubjub07 will weigh in.
good luck,
curbie
Yep, my experience as well. Even older am100 ROMs similar except device specific so skipped steps 1-3. Was really surprised to see an MBR on the front of the am1400 image I found. Was thinking I should strip that off before I try to use it for the zuluscsi.i disassembled a lot of am boot proms, at least the ones i looked at did the same thing:
1 get boot id.
2 jump to boot id routine.
3. check secondary boot routine. VCR, STR, FLOPPY, ...
4. read block one MFD.
5. find UFD for 1,2.
6. read UFD and load BADBLK.SYS if it exists.
7. find UFD for 1,4.
8. read UFD and load AMOSL.MON, it better exist.
9. jump to monitor init routine (which finds and executes AMOSL.INI).
possibly. it's an extra block in front of the volume label block, but it doesn't seem like a normal MBR.don't know mike, but could that be a part of SD formatting?
Joy! Successfully imaged the am1200 hd using the new "initiate" zuluscsi feature. Found that I must have done something when it first booted 'cause the tdv it was looking for was indeed missing (the '11' code). So changed amosl.ini to use ANSI tdv instead, and commented the trailing 2nd level BOOT command. Comes up just fine now and I have an sdcard backup.Think I'll get another scsi2sd and/or zuluscsi and replace the HD thou -- lots lighter & quieter.mike,
good luck,
curbie
VAM/L will be a free enhancement to VAM.don't know if it is important to you, but you can dump the UFD for DVR: and look at the .TDV entry which should still be there for a ":80" (erased) or garbage over the entry (machine fart), to try to determined what happened, erase was a mistake, machine fart may mean still a problem.
what are you going to do with your VAM/L emulator, if for sale, i'm interested.
