johnnycontrario
- Joined
- Jun 23, 2023
- Messages
- 54
Well I offered $300 and they took it. The adventure begins
| VCF Latam | Apr 24 - 26, 2026, | Bahía Blanca, Argentina |
| VCF Pac. NW | May 02 - 03, 2026, | Tukwila, WA |
| VCF Southwest | May 29 - 31, 2026, | Westin Dallas Fort Worth Airport |
| VCF SoCal | See you in 2027, | Southern CA |
| VCF East | Apr TBD, 2027, | InfoAge, Wall, NJ |
Priority one considering the current PAK situation.I would also export (and re-import) the licences.
Funny you should mention this. I was following these instructions last night, but I was getting error messages when issuing the `RUN SYS$SYSTEM:AUTHORIZE` command. I did a little research, and it sounds to me like an ACL kind of thing where an executable isn't available or something like that. It was late (and ears ringing lol), so I didn't dig much further.You can reset the SYSTEM password...
once you have done that you should be OK. I think I would try something like a SCSI2SD to backup the disks. From what I remember the VMS backup command will copy to another disk. I would also export (and re-import) the licences.
Totally missed this. Sounds like a good solution. Still wondering about sd card longevity.I would try something like a SCSI2SD to backup the disks.
Some suggest getting "Industrial" SD cards.
I just backup the image file if I make any significant changes and take my chances with cheap (but name brand) SD cards.
Thats a bit odd. You could try network boot...Funny you should mention this. I was following these instructions last night, but I was getting error messages when issuing the `RUN SYS$SYSTEM:AUTHORIZE` command. I did a little research, and it sounds to me like an ACL kind of thing where an executable isn't available or something like that. It was late (and ears ringing lol), so I didn't dig much further.
are you logged in yet?It was mentioned that you could export/import the license. How exactly do you do this?
RUN SYS$SYSTEM:AUTHORIZE. I'm thinking of reproducing the issue in AXPbox to validate my theories. I'll post a new thread if it gives me any trouble or if I learn anything interesting.Probably not very viable. I do have it in my DS10s, but it was a job to do and it's not bootable. I doubt the AS400 has firmware new enough to recognize a SATA HDA as the latest (and last) Alpha firmware for the DS10 did not. This means you have to configure the card and any disks in another system which does recognize the HDA card. In my case, it was an HP P410 SmartArray and I had to acquire an HP system that was supported and a Windows Server version that worked with the HP ORCA SmartArray management tool. I guess there are non RAID SATA HDAs around. You need to look in the driver database (SYS$SYSTEM:SYS$CONFIG.DAT) for your version of OpenVMS to see if there is anything compatible. Again, you won't be able to boot from it, but once booted you can set it up as a data disk. It might be a bit labor intensive, but you could make the ZuluSCSI/SCSI2SD/PiSCSI the boot drive and configure swap/paging/user/data etc on the SATA drive... Well maybe not the page/swap. That might take some investigation on how soon the drivers are loaded so the SATA drives are available. Perhaps a small primary swap/page on the SCSI and then a larger secondary page/swap on the SATA.Meanwhile, I had a dumb anachronistic idea. This thing has regular PCI slots, so I was wondering how viable a SATA controller would be. I guess the 2 main questions are support in SRM for booting and support in the OS. OpenVMS 8.4 was well into the SATA era, but I don't know if that means anything.
