RE: Hard drive - yes, I hear the platters turning. If you know of any good DIY guides to repair the HDD, I'd be grateful - frankly, I'd written it off...
The hard drive controller is also 'in the equation'. (Yes, it is more likely that the HDD is the problem.)
In case of poor connection, reseat the controller in its ISA slot a few times.
In case of poor connection, reseat the connectors on the drive and cables.
Although you hear the spindle turning, there is a possibility that deteriorated (or partially solidified) spindle lubrication is resulting in the spindle not reaching full speed. We have had cases of people being in a similar situation to you, and their HDD 'comes good' after it has been left running for a while.
Deteriorated
aluminium electrolytic capacitors in the HDD ? (They can dry out.)
All kinds of possibilities.
What is the make-mode of HDD controller and drive ?
As for the GoTek - no, I was totally unaware of this! I'll look into the jumper settings, as with the original FDD connected, I get no such errors!
The IBM PC family, and most clones, use a particular type of 'twisted' floppy cable, shown at [
here]. Accordingly, the drive-select jumpers on both attached floppy drives are set to the second drive-select position.
The PC1640 is an example of a clone that uses an untwisted cable. I presume that the first drive (A) is set to the first drive-select position, and if a second is fitted, that one set to the second drive-select position.
