Trixter
It's a resounding success, with the exception that it decides to just quit on me, as if I had exited manually. This last time it exited, I was in the middle of typing a reply:
You can see me type "But, display issues aside, I " before it craps out.
Spurious keyboard interrupt? Is that an error output?
Display speed is fantastic, btw. I am curious how your "snow value" works (ie. higher numbers = less snow) but I'll respond to the snow discussion in the other thread first.
irc.gimp.ca 401 _Trixter_ This :No such nick/channel
brut_pcjr PRIVMSG #vc :You don't need to enter a command to send a msg, unless y
ou really want a private message.
brut_pcjr PRIVMSG #vc :Try this:
brut_pcjr PRIVMSG #vc : /privmsg brut_pcjr :msg goes here
_Trixter_: Okay, so this message is public...
_Trixter_: /privmsg brut_pcjr ...and this message is private
brut_pcjr PRIVMSG #vc :Yep - by default everything goes to the channel that you
last joined.
brut_pcjr PRIVMSG #vc :Just type and it will go to the channel. True 'private m
essages' will come later.
_Trixter_: Every message I'm seeing says PRIVMSG #vc :..... so I can't tell if t
hese are private or public
ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ
But, display issues aside, I Irc Stats: Ping Responses: 0
Tcp Pkts Sent 39 Rcvd 37 Retrans 6 Seq/Ack errs 0 Dropped 0
Pkt stats: Incoming pkts: 296 Dropped: 7 Sent: 48
LowFreeBufferCount: 0
c:\internet\brutirc>
