cwathen
About to do my first ever flyback transformer replacement. The monitor in question (an Amstrad PC-CM) was arcing like hell in 2014, and confirmed due to a dead flyback by an ex-TV engineer I knew. At the time no flyback could be sourced so I just sat on the monitor (complete Amstrad PC system in fact) in case parts were ever needed for my second, working system.
I've just found a NOS transformer and assuming nothing else is wrong hope it will be a simple enough job to swap it out and get a working colour monitor to go on my RM Nimbus PC.
Firstly, I would assume since no attempt has been made to power it up in over 5 years that the monitor would definitely be safe to work on now!
However, just in case I want to try discharging it...the trouble is every video I've ever seen on the subject is on a discharged tube where nothing happens. Part of me would wonder if just having a little wiggle under the suction cup with a grounded screwdriver and getting nothing was because it is discharged or because I didn't do it right.
Does anyone know of any examples of a discharge on a *charged* tube which does go kerpap, mainly so I can see where they've poked to make that happen?
