Any idea what this Raster Output Board is?
wrljet
Maryland
Found in an estate cleanout.
It has a DE-15 connector like a VGA, but with male pins. The main chip is an FPGA (sorry for poor picture).
I think the problem might be that it's incomplete. U1 appears to have been removed. I strongly suspect that it's part of a multi-board setup. The only mentions on the web that I can find reference this exact board.
I'm not totally sure about that; there's currently one on Ebay (with a different serial number) that is also missing that chip, and it wouldn't be the first board that had pads for a chip that's not installed.
Though just as well it could be some particularly valuable chip that often gets removed from these boards by scavengers, I suppose. And it is weird to me that it still has the caps around the pad, though perhaps it's just cheaper always to install those than to sometimes not.
It's a mystery. As to what the board does, I could hazard a guess if the part numbers of the smaller chips were known (not easily visible on the photos) U2 is a clock driver and U4 looks to be a crystal/XCO for it. U5 appears to be a differential line receiver, U5 and U7 are illegible from where I sit. Could this be a gizmo that switches a signal between several displays, but keeps the H and V raster drivers for all displays synced? Just a wild stab in the dark, but it seems to fit, particularly in view of the DS1-DS8 LEDs. Alternatively, I suppose that it could be part of a video production setup, where several inputs could be selected, all sharing a common sync to avoid glitches when switching from one to the other. Not really my wheelhouse.
U6 is an Altera ACEX programmable logic device. U7 is some sort of TI part that I can't see well enough to identify, but maybe someone more familiar with TI stuff from the PCI era will recognise it. Here's the pic from the Ebay auction I mentioned above.
