MicroCoreLabs
- Joined
- Feb 12, 2016
- Messages
- 709
The PCjr Racore upgrade has a switch on the back for PC/PCjr mode, so I thought I could add something similar... The interesting thing is that when I set the cpu-type to IBM PC, DOS 2.1 still boots in 40 column mode... If I recall correctly, when the Racore is switched to "PC" mode it boots in 80 column mode... so maybe the Racore switch does more than just set the computer-type field. Also when I set this DOS 3.2 does not boot at all, so there must be more going on here than just this field... Maybe Racore is patching a large amount of the BIOS?
