Anybody know what this is?
egnuldt
Colorado
Not sure what it is, it doesnt have a brand or any numbers model # or anything.
Thanks for the help.
Seems like some kind of late 2nd generation (of definition) or 3rd generation computer. It depends on if it got transistors or IC's.
I would date it to either the late 60's or early 70's. It may be something published through a magazine, like the last unknown (and in many ways; quite similar) computer up for discussion here.
It may also be related to the other items you just made a thread about.
Thanks, I appreciate your responses.
I cant seem to take the machine out of its case (big black plastic case - like the ones that hold all of the Wilson Laboratories Disk Exercisers). It looks as if you take it out to operate it, but its completely stuck/attached from the back of the machine to the case.
Do you think it would be safe by just yanking/prying it out of the case possibly without damaging whatever it is attached to (if its attached to something).
Thanks.
Edit- Ok nvm, its bolted to the case
Think it could possibly be a tape exerciser as well? It has read/write ability with head alignment ability.
Ok, took out the bolt/etc here are the pics
Magnetic Peripherals, Inc. TB216A
Well At least Im using my 1Kth post for something useful,
It's an SMD interface'd drive tester/exerciser I've one in the large black case upstairs.
You can use it to set up seek patterns to test the servos, do writes & reads to test heads & i/o and quite a lot more. I haven't got an instruction manual though, so I can't be of much help & I've not had to use it yet, so I've not tried to learn how to use it properly, and it's 25 years since I used a similar one.
