I'm not easily finding any good references to repair/disassembly for these PC-5 systems. They're a hand held computer that apparently has a minimal dos 5.0 load and an 8088? chip so it's "compatible" with already compiled programs you could technically transfer to it via the serial port and kermit protocol (one I have works and counts 640K ram which is amusing) the other just makes a horrid buzzing noise when plugged into a power source. Obviously I'm guessing the battery or a cap is shot inside but was hoping to look at some guide to repairing these. Unfortunately most of what I find leads to the fairly nondescript corvallis website which no longer references these units and certainly seems like they used to just have you ship them the unit and fix it for hundreds of dollars.
Anyone play with one of these? This http://www.cmtinc.com/techhelp/pc5faq.html is pretty much the most information I've come across so far but nothing really about the insides. They have an ftp I looked briefly through but it also seems to concentrate on using the newer models and not anything regarding repair that I could find. Really I would think they'd have something somewhere on replacing the battery as an FRU but perhaps they weren't intended to be field replaceable?
It seems like it was popular with folks doing geological and forestry studies. Certainly looks more like something you'd find in a warehouse than a home though. I tried on the classiccmp mailing list but no response there lol. I haven't tried too much as the screws weren't budging from my first attempt but I also had a smaller screw driver and thought I was going to strip the screw or they may have used some sort of sealant on the screw. Any tips would be most welcome.
Here's a picture of one.
The reason I was intrigued was the text on the systems that says "MS-DOS 5.0".
