tony359
- Joined
- Sep 30, 2020
- Messages
- 67
Hi all,
I'm fixing an Apple //c, the ALPS drive is kind of working but it fails all general tests from MECC and XPS. Also it reports a speed of 400 or 600RPM (depending on when I try) but I am 100% sure the speed is correct as I can see the 50Hz pattern still and I also have a tachometer to check. Might not be exactly 300 but definitely not 600 The pulley spins freely when the belt is removed.
I can boot from that drive and works with most of the software but not all. The same issue happens when connected to my Apple //e.
I'm checking schematics and testing signals but I'd like to understand how the software determines the speed of the drive?
Thank you!
Thank you!
