I can be a bit disorganised and always find heaps of chips when I clean up my workbench, I currently have about half a Kg of TTL and memory chips of unknown status. Periodically I sort them and use the tester on them before putting them back in the parts drawers.
Mine is due to be replaced soon, the test button has gotten a bit flakey due to over use.
Well ,its been a while since last post, but the Apple is now working !
Got the LS tester and tracked down a faulty chip eventually, but hampered by a recurring PSU fault. It would start and run fine then fail to start without warning. Stripping it our would always fix it, but the last time it also failed to run when on the bench, but sprang to life with a small prod.
Had a good look round and soldered up the collector on the big transistor and that seemed to have fixed it (it did suffer quite a dramatic failure and needed all power caps, plus the rectifier replacing to fix initially)
So next is the keyboard. Now stripped and the faulty stalk removed, just waiting for a replacement. Three of the little 'buttons' aligning the contact strips did come off when the strip was lifted (not the bigger ones, but the little ones at the end of a strip), but a melted blob from a cable tie, shaped to match has fixed that.
Just on the lookout for a Disk II to complete, though an emulator would probably be better.
Anyway, this is fun. Almost time to switch to the TRS-80 and see if it still works.
Eeek, just noticed it was July when I last updated, where does the time go. I need to retire.
