Back to this board after getting the TRS80 and Microvax up and running.
Can now get it to boot fine (never found out why one working disk interface didn't like this machine) and I have been using it to diagnose a Disk II i got for £5
New problem is my Vergecourt RAMEX 16 memory card has gone flakey. Tends to work when turned on, but fails after about an hour of use.
One chip, one of the multiplexors 74LE153N has a broken pin. Was really floppy when removed and snapped when touched. This could easily be the fault (I hope) and a spare on order.
The second, is a 74121N, a monostable multivibrator.
Now, this one tests as ERR in my chip tester, and I have a new one on order,
but I wonder do these ebay chip testers successfully test this chip (given a possible need for external RC network) ?
and, what is this potentiometer for ?
http://www.quartdepomme.fr/quartdep...cards_(Updated)/Pages/Memory_RAM_cards.html#1
Cant find a circuit diagram. It might be the external timing circuit, but that would be odd to leave to the vagaries of a crappy carbon track, though I suppose if the manufactures had a problem with timing and had to trim each one, it might have been required.
