I used MartyPC first time to run Area 5150. Yes Area 5150 works well nearly perfect to IBM PC 5150.
I use PCE 5150 Emulator with original IBM PC 5150 / 5160 configulation.
MartyPC still doesn't support FDC (Int-13) emulation fully for disk copy protection.
Also it can't set up user configulation.
So far, the MartyPC emulator does not allow the user to specify the settings of the IBM PC 5150/5160. Important disk protection is not supported, EGA / VGA is not supported.
On PCE, most of the 1000+ disk copy protected software I have works just fine.
However, it is worth praising that it implements smooth scrolling and the Area 5150 somewhat well. Also, I personally use the IBM PC 5150 / 5160 BIOS to run PCE, but MartyPC still can't do that.
