modem7
10k Member
The 24 pin U33 BIOS ROM will not work in the 28 pin socket - different pinouts.Crap, well anyone else out there watching, can you confirm is it a futile mission? 24 pin to 28 pin adapter to plug in my Dallas No-Slot-Clock, and then plug my 24 pin ROM into the 28 pin socket on the clock?
What should work is what SpidersWeb wrote: The adapter you bought into the U33 socket, then the DS1216E into the adapter, then a 27xxx (or 27Cxxx) EPROM copy of the U33 ROM into the DS1216E.
1. No guarantees.
2. The U33 socket sits at address FE000, not F0000, and so the software at mbbrutman's web site is not expected to work. Try alternate DS1216E software.
3. When creating the 27xxx EPROM copy of the U33 ROM, the 8K image of U33 needs to go into the last 8K block in the EPROM (because of the particular adapter your bought).
Basically you will be doing what is described in the OPTION 1 area of http://www.minuszerodegrees.net/5150_u33.htm , except that you will be putting a DS1216E between the adapter and the 27xxx EPROM.
