AT 5170 problems
framer
Murrell's Inlet SC
I have an old beater 5170 MB that I use to test old boards with. It started throwing off all sorts of error messages then would start runing very slowly....and on and on...
After checking everything that I could think of I noticed the cpu seemed hotter than I thought it should be. I put a good size heat sink and fan and it runs fine. So what could cause the 80286-6 to run this hot it's not over clocked. Too hot to hold your finger on it.
framer
I have no idea what might be the problem, but I may make a guess:
I assume the MB has been inside a chassis and well grounded.
If not, external moving charged objects may have partally broken some isolating material between two lines inside the CPU, causing a short-cirquit which might not be signifficant enough to acutally break the operation of the chip. This is a risk with all finer electronic devices, and this is also why nobody should ever use foam-peanuts when shipping such devices.
I suggest you run some kind of burn-in check that tests all the instructions and registers of the CPU for an hour or two, in order to guarantee relaiable operation.
Did you try plugging in another 286 chip to see if it also overheats ?
I recall there was a hardware hack to replace the crystal on the 5170 MB to force it to run at 8Mhz.
I'm sure some of the 6Mhz chips would run okay at 8Mhz, could that be the case here ?
Does the crystal say 12 Mhz or 16 Mhz ?
Interesting answer. I said it is a beater. I bought it for a late third party BIOS that it held and was used elsewhere. It came from a junk bin and has been without a case for years. It now has an old 1st generation BIOS that came from the board that got the new one. I will get my hand on a new CPU and see what happens. I'd bet you're right.
framer
It's doubtful that styrofoam peanuts could have nuked a CPU installed on a board--there's plenty of static protection afforded by the connected components. Still, the CPU could be suffering from other physical problems.
Reminds me of when MOSFETs made their first appearance. Some where shipped with a wire bridging the leads; it didn't take much to punch through the gate barrier. After you'd installed the FET, you clipped the wire between the leads. Once in a circuit, the danger of ESD was much lower.
In addition to checking the power supply voltages, I would check the ripple. An oscilloscope is ideal, but a multimeter set on AC will work in a pinch. The 286 CPU runs directly from 5V from the power supply, unlike modern PCs where the CPU voltage is derived from dedicated onboard voltage regulators.
If that looks ok and swapping the CPU doesn't fix it, the only other thing I can think of is some weirdness with the clock generator.
I didn't say styrofoam peanuts was the cause of the problems, but what I said was that you should never ship finer electronic devices (like chips and ISA cards) using them.
Regarding the CPU, it could almost be anything that's causing the problem, and my guess was not limited to just styrofoam peanuts as I was reffering to anything that can store charges (even ionizised air, but that's very unlikely).
Note that that is normal for an 80286-6 in a 5170. I'm not saying that your CPU isn't overheating; I'm simply saying that the normal running CPU temperature is such that it is, "Too hot to hold your finger on it". If you have a temperature probe, we can do some objective measurements.
To bring those interested up to date. I can run that system all day with a heat sink and fan then remove and it will throw an error within minutes.
Not having another 80286-6 to play with, can I install a faster -8 -10 or -12 processor [funny]or will it void my warranty[/funny] and expect it to work at the slower clock setting.
framer
framer
By the way, what kind of socket is is? It may be as simple as a leg which don't make proper contact with the socket. When the chip is heated, the metal slightly increases in size and that may cause improperly connected pins to loose contact completely.
Here's a consolidated list of possibilities suggested so far:
1. Dud 80286-6 (suggested by several posters).
2. Overvoltage (suggested by Chuck), e.g. 6 volts instead of 5 volts.
3. Overclocked due to upgraded crystal (suggested by Mikey99), i.e. something greater than 16 MHz (since an upgrade from 12 to 16 is a well known 5170 upgrade for the first models).
4. Overclocked due to 82284 failing (suggested by Chuck & james1095) in a really unusual way.
5. Poor connection (suggested by per).
6. Operation of motherboard in ambient air temperature above what the motherboard was designed to handle. The 5170 Technical Reference specifies that temperature for around the 5170 chassis, not the motherboard. For the 5170: Maximum ambient air temperature of 32 degrees C (90 degrees F).
__________________
burn wii games without a mod chip
copy wii games to dvd
All of the 5170 motherboards I have seen use ceramic PGA 80286s.
Quite right. Most 286 motherboards used the PLCC or LCC versions. IBM was a bit of an aberration. Never did figure out why--we had early 80286 steppings (pre-production silicon. circa 1981-82) and all of those were ceramic LCC. When I saw the innards of a 5170, I was a bit surprised at the CPU package. Most people don't realize how far behind the state of the art the 5150 actually was.
I'm still following this thread. The PS I feel is not the problem. I've got 3 5170 PS's and they've all been tried and power levels checked. I've been looking for another cpu with out success so far. I really hate to pull a cpu out of another good machine and risk causing problems with it. It still runs fine with a heat sink and fan.
framer
