I have a Gateway 2000 P1-75 it uses a AT power supply the two split six pin plugs. There is another six pin plug of the same type right by a PCI slot. I did some research and it seems there are two of these extra connectors. One has ground and 3.3v on the pins and one has ground, 12v and 5v on the connectors. I think this is for the 3.3v one, because they say the other one is used on ATX motherboards. Is this correct? Anyway to be sure? I can't seem to find any info on the particular Gateway.
Thanks
Russ
Thanks
Russ
