Ahm, I cannot thankyou enough for the code for clock.sys. I checked the clock402.txt installation instruction file, and sure enough, it is in there. Being a male, I never would of thought to check in there
. Seeing it was a .sys file I had just jammed it into my config.sys file without reading the directions. I guess I will do that next time I have trouble with something.
Bill, I forgot to include the DISKS in the list of what you should have. I have done that below. Depending on what year AT&T you have it will be different. I will list both what my DOS 2.11 and 3.2 AT&Ts have.
DOS 2.11
AT&T 6300 Mouse software Diskette
MS-DOS Supplemental Programs Diskette
Customer Test Diagnostics Diskette
AT&T 6300 Tutorial Diskette
MS-DOS/GW-BASIC System Diskette
DOS 3.2
MS-DOS System Diskette
MS-DOS/AT&T Help Diskette
Tutorial Diskette
ScanWare Program Diskette 1, 2, and 3
You will have different versions depending on your DOS realease and year, which is why I didn't bother including version numbers.
--Ryan
