True, but if I messed up making this cable I'll probably mess up making the Amiga's cable as wellThe 1080 should work. Even if vhold was out of wack on it you would at least see a rolling picture of some kind.
I’d try another source just to rule out issues with the monitor. If you get a picture with your amiga then you’ll at least know it’s your cable that’s the culprit
That would be helpful, thanks! I'll see about getting some composite sync out of my ST.Ooo looks like you may want to try that composite video circuit after allI have a 1080 to amiga monitor cable lying around here somewhere I can tone it out and see if it is in fact using composite sync
Ah! so that's the problem then. I had it right the first time, trying to use only composite sync. Except that a) I don't have a composite sync and b) my wiring diagram was backwards.So I just checked my commodore branded cable for the amiga to my 1080 and there is only csync. Pins 8 and 9 on the 9 pin din are not connected
Looks like Rev. CWhat revision board do you have? It’s also very coincidental that the silkscreen is showing 2 diodes, 3 resistors and a transistor and those are exactly what is required for that circuit haha. I tend to gamble though but I think it’s probably a safe bet
Great to hear you got it working!!Alright got the components and it's working!
Only strange thing is R51, for whatever reason, one of the holes isn't a hole, it's just a pad, it doesn't go all the way through. For now I just kind of surface mounted the leg on that side but I found where it connects to that pin header row (unpopulated) so if it breaks loose I'll run a wire to there.
The monitor is kind of soft though I may open it up and see if there's any internal adjustment pots I can try, like a focus.
yeah, thanks for the help everyone! the focus was easy to adjust, it's looking pretty sharp now. my friend will be stoked to finally be able to use his ST.Great to hear you got it working!!![]()
