Tor
My father still uses a modem.. and the screetch is when you connect, when you're getting connected it goes silent. So to have something similar for telnet I guess you would make something that sounds like it goes through the speed negotiation phase as soon as you hit 'telnet <somewhere>', then goes into a stable mode where the screech ends its stepping sequence, before it finally goes almost quiet and then goes completely quiet just when you get the remote prompt.
Then add blinkenlights somewhere..
-Tor
-Tor
