vladstamate
Hi all,
I am trying to make my 386 PC boot and here is the problem I am hitting. It has 2 floppy drives, a 5.25" and a 3.5". It seems to be setup that A is the 5.25" and B: is the 3.5". There is no autodetect in the BIOS (which is AMI btw) so I have to set it manually in there. I do not have a 5.25" bootable disk (no any way to make one) but I can make (and have) 3.5" ones. However the BIOS keeps trying to boot from the 5.25". Here is what I have done
1) Both drives connected and both set up in BIOS: it keeps trying to boot from A: (which is the 5.25") and complains (rightfully) that I do not have a boot disk.
2) Disconnect the 5.25" one (physically disconnect the data cable from it) but leave both set up in BIOS - it does not use the 3.5" and immediately complains that it cannot boot from A (it does not spin the 5.25", as there is no data cable to control it)
3) Disconnect the 5.25" one (physically disconnect the data cable from it) and have only the 3.5" set up in BIOS as B - it does not use the 3.5" and immediately complains that it cannot boot from A (it does not spin the 5.25", as there is no data cable to control it)
3) Disconnect the 5.25" one (physically disconnect the data cable from it) and have only the 3.5" set up in BIOS as A - it does not use the 3.5" and immediately complains that it cannot boot from A (it does not spin the 5.25", as there is no data cable to control it)
In other words, I do not seem to be able to convince the BIOS that the 3.5" is A: and to try to boot from it. I looked at the disk controller card but there is nothing obvious I can do. There are some jumpers though. Note that both drives use same cable so maybe the cable is at fault here (in the sense that it forces certain drive orders).
Any ideas of how I can make the PC boot from the smaller drive?
Regards,
Vlad.
Regards,
Vlad.
