MattCarp
Well, I hate to say it, but I'm now stuck.
My PDP-11/73 autoboots the primary RQDX3 disk drive just fine (which is running MicroRSX on a Seagate ST-251-1, I think).
But, the real fun is with SCSI. So I got an Emulex UC07 and Seagate 4GB ST15230N SCSI disk drive.
Earlier, I was able to write an RSX-11M 4.6+ image to the Seagate disk with simh. I can boot that disk image from simh, and used linux to write that image to the physical drive with dd.
I then went ahead and installed the drive into the PDP-11 BA23 chassis, installed the UC07 SCSI controller at the alternate address of 17760334.
I was able to use ODT to start the UC07 Firmware Resident Diagnostics. I used this to set the UC07's non-volatile RAM settings. I left most everything as default, except:
- set LUN to 4 (since RQDX3 is at 0, 1, 2)
- Type Code to 4 (autosize device)
- Full Capacity = Y
I can start the machine in dialog mode, and, boot du0 to start MicroRSX. I can also boot the RX50 at du1 and du2. I do have XXDP 2.5 on floppy and that boots fine.
DU3 comes back "Message 15, non existent drive", which is good. That's what I expected, since there is only one hard disk on the RQDX3.
DU4 comes back "Message 11, Non bootable media in the drive" uh-oh
I thought, "no problem", I'll just write the disk image over serial to the physical disk with PDP11GUI. The Read/write disc image tool reports "receive timeout in state 0". I've made sure I selected controller type = MSCP, put in the proper controller address 17760334, and chosen unit 0.
Of course two MSCP controllers is possible, but it seems that another forum user did it with the UC07 as primary: https://forum.vcfed.org/index.php?threads/correct-mscp-secondary-csr.63645/ However, I'd like to keep the UC07 as secondary for now.
I believe the hardware is good. In the UC07 FRD, I can see the disk drive. When I "List Known Units" it says Drive 4 is Available and a unit size of 8386733.
Also, the dialog's return message of "non bootable media in the drive" suggests the PDP and the UC07 is able to get something from the drive.
At this point, I think my image could be written improperly, or, ...?
What's the easiest way to reload the SCSI disk drive? I thought PDP11GUI would be the easiest, but it's turning out not to be the case!
I seem to recall I used TU58EM and XXDP a very long time ago to load MicroRSX, but I certainly don't have the steps now.
Also, I'm going crazy trying to be sure I'm sending either a line feed or a carriage return from my Windows CoolTerm or the PDP11GUI Terminal. Any hint there would be appreciated.
I feel like I'm close, and just need to be pointed into the right direction.
I am also happy to hear the feedback "hahahaaha, you should stick with Macs and 8-bit machines you mortal!"
- Full Capacity = Y
