thunter0512
The VR14 uses a bridge rectifier made up from two "half-bridges" with two diodes each.
The writing on the rectifier says "MDD DM 15". The parts list in the DEC VR14 Engineering drawings refers to it as "DM-15".
Does anyone know what this part is properly called and if there is a datasheet for it and if it is still available or what a good replacement is?
Here is a photo:
Here is an extract of the VR14 power supply circuit diagram showing how two of these parts are used in a bridge rectifier configuration:
Here is a photo:
