shirsch
Unfortunately this implementation is best suited for the CYCxxxx single-board computer which is pure unobtanium.Or you can go this route: https://pdp2011.sytse.net/wordpress/pdp-11/
That is only one choice of many FPGA boards. There are many other alternatives...Unfortunately this implementation is best suited for the CYCxxxx single-board computer which is pure unobtanium.
I'm just going by what the author told me when I wrote to ask about CYC1000 availability. I have a couple of the alternate boards here and will try to dig back into the subject. Thanks!That is only one choice of many FPGA boards. There are many other alternatives...
'best suited' is only applicable if your only criteria is absolutely smallest size.
A VME backplane?In my idea my system will use 32 bit eurocard board backplane
No, ECB backplane derived from the N8VEM project. "Derived" because that bus is not conceived for a PDP architecture and some signal name and usage shall be changed accordingly. I noticed that other users here went on that same roadA VME backplane?
Another benefit of the N8VEM ECBs is that for just 10 bucks you can find the bare unpopulated pcb onlineA VME backplane?
I aim to run BSD 2.11, and indeed you are right, hardware-wise the I/O I need to implement will have to be as similar as possible to original DEC devices. I know other members (and non members) managed to adapt modern devices to mimic the original hardware, for instance the 6402 uart can be adapted to become a serial interface, other managed to create an hard disk interface, and the list goes on. As for writing my own device drivers, hmmm that will have to be seen accordingly to what will come up, but I will try to keep that as low as possibleBefore you go too mad (!) perhaps you need to think about what software you want to run, and how that will impact either your choice of hardware or whether you will have to write bespoke device drivers for your non-standard hardware.
Fair question, "just for the sake of it" would be the most honest answer. Of course I wish to learn something new, hone my skills and have loads of fun... but ultimately having a mockup of a PDP11/70 sitting on the shelf would be nothing if you can't power it up and make it workI thought I would just plant that seed in your mind...
What are your intentions for this board?
Is it for the interest of 'just doing it' or is there some other reason?
I'm still in the brainstorming phase, as soon I have read and studied enough I'll open a new thread with some more specific data. I'm open to all suggestionsThat's a fair enough answer... And probably the same answer most of us would give if truth be told...
It will keep you off the streets at least !
Well, those would very likely be only A-C connectors (64-pin) which may not be sufficient for your purposes (Qbus is 72-pin, right?).Another benefit of the N8VEM ECBs is that for just 10 bucks you can find the bare unpopulated pcb online
Indeed I'll have to check that, but I kind of remember reading the N8VEM ECB backplane was expanded years ago in order to support 16 bit systems, with 24 bits of address space, so this would fit perfectly.Well, those would very likely be only A-C connectors (64-pin) which may not be sufficient for your purposes (Qbus is 72-pin, right?).
A-B-C DIN connectors (96-pin) are much more expensive and harder to obtain, as well as backplanes, because you've moved into VME territory.
The 8-slot backplane is indeed ABC (schematic attached). So is the 12-slot backplane (schematic attached). But once you price in the pairs of 96-pin connectors you may find it cheaper to acquire an existing "half-VME" backplane. Or a full VME backplane; think of it as QQ/CD (or QQ/QQ). And you'll have a more favorable board size to work with. At which point simply adopting a 4-tab DEC Qbus backplane begins to look ... favorable! It's a slippery slope, yes ...Indeed I'll have to check that, but I kind of remember reading the N8VEM ECB backplane was expanded years ago in order to support 16 bit systems, with 24 bits of address space, so this would fit perfectly.
You are so right, I'll make some order in my ideas and open a new thread@sam2000
I have the same project as you, building a PDP-11 with a DCJ-11 CPU, I've bought a few.
However, I'm thinking of using 4 DIN41612 48-pin connectors to make it look like the original Qbus.
For this project, I want to use contemporary components from the DCJ-11 (1983-1990), no SMD parts, no big CPLD
I think you know this site (ECB bus for PDP-11) :
System Bus · My PDP-11 Projects
www.5volts.ch
Perhaps you could open a dedicated topic so as not to pollute @maguro 's subject?
you mentioned on the hackaday site a gitlab repo - could you please share a link to that repo too?Well, I have started on doing exactly that last year (then the money supply went dry due to other emergencies), but I'm not giving up.
here's what I have so far
