TomL_12953
I have a PET 2001-32 with a chicklet keyboard and built-in cassette recorder. It uses the upgrade BASIC ROMs (### COMMODORE BASIC ###) so I know the IEEE routines have been debugged.
I also have an 8050 dual drive attached and can load directories, format disks, copy individual files, load, save and verify programs with it. When I try to DUPLICATE a disk (0 to 1 or 1 to 0) however, it goes through all the motions, steps the heads, etc.
but right before the end, the LED alternates between red and green. Once the process is done, the LED stays green and the status shows OK. When I look at the target disk's directory, though, all I see is a disk number and a reverse video quotation mark. No filename or any other info. I'm using 97 TPI disks with a hub rung (not HD disks). Does anyone know why this might be happening? Thanks for any info you might be able to give.
Tom Lake
Tom Lake
