CBM 8032 for repair
Although (with a bit of luck) you might not need it for this PET repair...
If you get bitten by vintage computer repairs, then a logic probe will be invaluable - until you want more extensive test equipment (like an oscilloscope).
I’ve ordered one, never know might need it for the PET and the Apple 2 I plan to buy one day.
So now that you’ve mentioned oscilloscopes, any recommendations? Probably not a full blown one just a hand held.
The chirp is good. It indicates the initialisation process is running!
Voltages all look good.
Try the monitor now...
The clip is not something standard for a PET. It is likely that there was some add-on cards present at some time in the past, and this is a hang-over from their removal.
Hi Dave
It lives!!!
Although is that amount of bytes free correct?
Yep, bad DRAM.
I am out for most of the day with work.
Do you have the capability of burning an EPROM (or know someone who can). A 2716 (single rail) type.
You can burn my PETTESTER into it, swap it for the EDIT ROM, and it will test the machine for you.
Hi Sarnian,
Welcome to the world of PET! (Or should that be UK spec, lol). That looks about right for the fuse. I always keep a few spares handy. You can get fuse holders that fit in the fuse slot, then you can use modern fuses, which can be easier to source.
Before powering up, I'd check the voltage regulator. They're a known weakness and can take other components with them if they go. There are plenty of articles on the web about replacing them with more modern equivalents.
Let us know how you get on.
Yep, bad DRAM.
Hi Dave
It was all going too easy lol. Well at least I’ve got something to fix apart from a blown fuse.
I have an MM2716Q I could try?
Thanks
Robert
The EDIT ROM starts at address E000, so UD7.
I will check tomorrow regarding a 2732.
Thank you, that helped.
2732 does work, just put zeros in for the first 2K and your program in the last.
Now I’ve just got to work out what that mem fail code means, I’ll continue reading your instructions.
Thanks
Robert
Yep. You write my program in the 'top half' of the EPROM.
Alternatively, you can duplicate the program.
Yep, UA5 is to blame...
You are a very good student!
I did try the duplication trick but then I was in the wrong socket at that point. Doh
Assuming it’s just UA5 at fault, is it just a matter of replacing that chip?
Would you socket or solder it back in?
Does anyone stock these?
I’ve found MM5290J-2 on eBay but mine are MM5290J-4, can you mix them?
Yep. Of course, my MARCH-C memory test may find another fault when it is run next...
Always use a good-quality socket.
The 'MM' means National Semiconductor.
The '5290' indicates it is a 16K * 1 DRAM device.
The 'J' indicates the packaging type.
The '-4' indicates the speed rating.
A '-2' is faster than a '-4' so is a suitable replacement.
A 'bog standard' 4116 DRAM will do perfectly well, assuming the speed (access time) is fast enough. Check the data sheet(s) for the speed ratings. The '-4' has an access time of 250 ns and a '-2' has an access time of 150 ns. See: https://minuszerodegrees.net/memory/4116/datasheet_MM5290.pdf.
You can (generally) 'mix and match' DRAM in a PET.
I would think twice about using eBay. Suitable 4116 devices are available from a number of suppliers yet. Although, putting the part in a socket, means that you can simply swap it if the replacement turns out to be faulty. However, this gets annoying...
Hi Dave
New DRAM arrived today from erm ebay ( I know you said to think twice but its from a seller I trust).
Memory test completed three times (should I do more?) and now showing 31743 bytes free.
Well thanks Dave for all your help, think that's stage one complete.
Unless you can help me with the following? Maybe should start another post?
The ROM I can only find reference on another post on this forum but no answer.
The hand writing meaning?
The card, yellow wires / red button resets the machine and blue wires/button makes a sound like a small relay clicking (not that there is one)
Excellent!
I would give it at least 20 passes for good measure.
Did you check the ROM checksums from the previous PETTESTER screen for correctness?
Oh well, it seems to run!
The ROM is the PAICS toolkit that adds additional commands to the PET's BASIC.
See: https://www.zimmers.net/anonftp/pub/cbm/firmware/computers/pet/other/toolkit-b000.txt
However, either this ROM is in the wrong socket or it starts at a different address.
The $B000 toolkit starts by entering the command SYS 45056.
Which socket is that ROM in?
The little board looks interesting...
If I get a bit of time I will sketch out the schematic.
Are there any more connections to that board other than the 6 wires I can see? If there isn't, this looks a little strange to start with...
The SYS 31283 sticker looks like it executes at $7A33 - which is in RAM (so this is not a ROM entry point).
Excellent!
No but I have now, it matches Basic row 4 on your table
Will give it some more passes tomorrow.
