FishFinger
I'm having trouble with a CGA/Mono combo card I got recently. The card is an ATI Small Wonder Graphics Solution. It can work in either CGA, or MDA/Hercules modes. It has both TTL and composite output, and you can set the monitor type independently of the mode, so for example it can do Hercules on a CGA or composite monitor - which is what I originally bought it for.
I don't have a working TTL monitor at the moment, so when I first got the card I tested it worked by setting it to CGA mode/CGA display and hooking it up to the TV on my desk with a composite cable. I got a nice steady picture, but since the TV doesn't support NTSC colour all I got was greyscale. Later I made a CGA to Scart adaptor, hooked it up to the same TV, and again got a steady image, this time in colour. So all appeared to be fine (see here).
When I tried it on another TV however, the video does not appear to be stable. The image has ragged verticals towards the top of the frame, as if the TV is having trouble syncing to the input signal correctly. At first I suspected my Scart adaptor, but when I tried with a composite cable I got the same result, so it would appear to be something else. I tried it on all four TVs in the house, and the only one that worked correctly is the 14" on my desk, which I'd tried originally. On any other TV I end up with something like this (with both the Scart adaptor or a composite cable):
Things are much the same in mono mode. With the card set to Mono mode/CGA display (I have no mono display) the three other TVs display a ragged image as above. The 14" on my desk acts slightly differently. It will display hercules graphics perfectly, but will not accept mono text modes at all (it displays a single frame, then blanks as if the input is not present).
