Al Hartman
Finally got around to making the cable for my cheapo IDE interface (http://www.lo-tech.co.uk/wiki/Lo-tech_TRS-80_IDE_Adapter_rev.2)
Making the floppy has been a bear.
I used the TRS32 emulator to boot the LD4-631.DSK image I downloaded from the Tim Mann website (http://tim-mann.org/misosys.html) and I used TRSTOOLS to create a blank 40trk DSDD LS-DOS DMK image. The original was SSDD and was a JV3 image which IMAGEDISK (http://www.classiccmp.org/dunfield/img/index.htm) can't work with.
Then, I copied the system over to it. And, tested that it booted. It worked fine.
I mounted the IDE.DSK image from the Lo-Tech website to copy the two driver file over. But, the image was password protected and wouldn't let me copy the files over within LS-DOS.
I had to use TRSTOOLS to extract the two files to my Windows 7 file system, and then import them into the new DSDD image. I rebooted the image, and the files are there.
Next, I copy the disk image to a floppy in my USB 3.5" floppy drive. I run Virtual PC with an MS-DOS 5.0 virtual machine, andconvert the disk image from DMK to IMD using the DMK2IMD program. I have to do it this way, because if I try to do the conversion on my 5150, the image it makes is unusable.
Now, I take the IMD image to my 5150 and use IMAGEDISK to write it out to a floppy.
I have to go do the last two paragraphs now. I'll post back in awhile with the results.
