giobbi
Hi all,
I finally got my PET/2001 working; since I have 4 bad ram chips, I had to build the RAM adapter with a single 6264 ram chip instead of the 16 x 6550 ram chips.
The PET boots fine, showing the right amount of memory, but it has some strange behavior.
First issue: if I try to run the CHR$(<N>) instruction, I always get the same symbol equivalent to CHR$(222) on my 8032, no matter what is the <N> value.
Second issue: if I run some simple basic program, after some time I get some kind of error (like "syntax error in ...", but not only).
Third issue: if I try to play Invaders (the 1977 one, with rough cubes instead of the space ships) it seems to reset in some way every few seconds (the game doesn't stop, I can continue to play but the ships position and number change).
Strange, isn't it?
I'm using the original 6540 ROM set plus the RAM adapter.
What do you think: would be a ROM or RAM problem? Well, I only wish to know your opinion before to start doing some test and diagnosis
--Giovi
Strange, isn't it?
--Giovi
