bobsstuff
I use an arsenal of cleaners:
cigarette Lighter fluid (naptha) for sticky things like labels (used to buy by the gallon)
WD40 for other sticky things that lighter fluid won't touch
Windex for NO scratch surfaces like monitor screens
Goo Gone more sticky residue stuff
Goof Off more sticky residue stuff.
Alcohol, best cleaner for keyboard grime. Just don't use Jim Beam or JACK. rubbing is what I use........on keyboards:D
Graffiti Gone Paint and marker pen -- my own "works almost every time" concoction. Disolves 20 year old paint. Takes out marker pen ink. I sold it for a while in small bottles, but never got the power to go commercial.
Simichrome Polish for polishing and smoothing
Mother's Mag & Aluminum Polish polishing again
Tape and other stickies require different cleaners.
Razor blades for peeling labels and tape off. Buy a box of single edge MADE IN USA blade. (I for why I did not like the foreign made.)
Always use a sharp blade. and run it almost parallel to the surface. With practice you will NOT cut into the paint or plastic of the item you are cleaning.
I put a drop of lighter fluid at the edge of a label and then peel under it with a razor blade. As the label starts coming off, I drip another drop of lighter fluid on the sticky part.
Be careful with any cleaner and test it on the bottom of an item first. Some of them will melt plastic.
Yellowing: It is a reaction between the plastic and UV light. It goes deeper than the surface. About the only way I have ever found to get rid of it is remove the surface.
With Macintosh SE computers I used to use #600 wet or dry sandpaper and a palm size electric sander to take off yellowing. I used it wet and yes I would disassemble the unit first. Care needs to be taken around logos and text.
Same wet or dry 600 on any yellowed surface. I do not do it any longer.
Anyone want to buy about 70 Mac SE & similar style computers, most with yellowing? LOL REALLY I have them --- STILL
Some monitors used to have a plastic coating over the glass. I guess it was a built in glare screen. I messed up a couple big CRT monitors trying to clean the screen. Use only window cleaner on monitor screens.
