falter
Hey guys.
Started organizing my stuff this weekend and came across my ADAM, which had not seen attempted use in over 3 years. I got it off the 'free bench' down at the local computer store. Basically it had a situation where the tape drive would just run endlessly in one direction.
Apparently these units suffered from an issue where what's called an 'encoder wheel' in the high speed tape drive would get gummed up with melted rubber. A drive wheel attached to a shaft that also was attached to the encoder wheel apparently could get so hot it would melt and thus cause the wheel to stick. Since the tape drive doesn't know where it is, it simply keeps going in one direction.
I know this because I stumbled upon a video on youtube here: http://www.youtube.com/watch?v=py5Y1PYUadY That guy is my hero. However like most of those videos some little items are skipped and I was wondering if any of you had advice. The 'gum' on the encoder wheel is quite thick. The video suggested using a solvent, but you never see the actual work going on. Also the encoder wheel's outer edge (the part that is sensed by the drive) is very flimsy plastic or metal. Very easy to break one of the fins. So I'm a bit nervous about scraping at it. Thus hoping there is a solvent that'll do the job. Any thoughts on solvents that would go after melted rubber but not eat the rest of the part?
