SomeGuy
But how does it look on a real Tandy?
Would this adaptation also work on a PCJr?
KEEN4T.EXE hard tedlevel 15
and press F10+M to see how much free memory (with purging) is left. Use KEEN4T.EXE easy tedlevel 18
to start the level that needs the least amount of memory. Disabling sound and/or music frees up some memory. When you start the game with tedlevel you need to press Ctrl+Q to quit the game, exiting the usual way will hang the system. The Tandy music uses code that's very similar to the Adlib music code, so I don't think that causes "hitching". Does it only happen when Tandy music is played?
