Hello,
i'm again with another commodore monitor, this time is a 1084S-D2 (Daewoo chassis)
This monitor is of my friends, it have buyed on line but during shipping it damaged! Opened monitor i have found a crack con the PCB bottom of flyback! My friends turned on the monitor when arrived but it don't power up, no led, no sound nothing, dead!
I don't know if the monitor working before shipping, my friends says yes but i'm not sure, then i have glued the 3 pieces of pcb, checked all component between crack and then i have soldered all pcb wires cracked, i have opted to se little wires for little pcb lines, and for ground i have soldered between crack with a wire to enforce.
Now the monitor powers up, led ok, but no raster, the tube glow up, if i connect my C64 i have only sound, contrast and brightness ti middle but nothing no raster.
I don't find chematics for D2 but for D1, it's seems the same without TTL switch on rear side.
Throubleshoting guide says " IF NO RASTER CHECK IC201 TDA2595 12v input, REPLACE TDA2595, CHECK 15v OUTPUT on FLYBACK.
Tomorrow i will check all power lines, but any idea from here?
Thanks
Emanuel
Thanks
Emanuel
