byteback nostalgia
- Joined
- Aug 30, 2024
- Messages
- 25
Hello,
So I just bought a C128, and it appears that the accompanying power supply wasn't providing the right voltages (tested after the fact). Following a purchase of a new power supply from Amazon, it appears that I have all the symptoms of a dead C128.
My troubleshooting steps are as followed:
- The power supply is properly reading 9v AC and 5v DC
- The power switch is working as intended, reading 5v DC and 9v ac, respectively. Continuity is working as expected when the power switches flipped both on and off.
- tested CR 15, and I think there was a problem here. I'm reading values in the mV. Attached is a picture of its reading on my oscope:
- Voltage regulator at u59 is properly displaying 12v
As shown, the vpp is 30mV and the max is 10mV. The diode tests at ~99MOhms
- Cartridge port is only showing 4.62v across pin 1 and 2
- The Z80 5v rail is showing 1.75v on the 5v pin to GND
This is my first time attempting to fix broken hardware, so my experience on this is very low. Commodore is also a machine I haven't really touched either. Does anyone have any suggestions for me so I can move forward on troubleshooting? Thank you.
