I finally got around to repairing a Commodore PET I bought a few months ago and managed to get it to display the following:
*** COMMODORE BASIC ***
7167 BYTES FREE
READY.
However there is no cursor or any response from the keyboard. Before it gets to the prompt, it does display a bunch of random characters for a brief second.
The cassette motor runs constantly (as if you hit the play button), and the LED on the board isn't on (not sure if it's supposed to be or not).
The voltages to the cassette are:
Motor - 2.3 volts
Read - 3.1 volts (this seems odd)
Write - 5 volts (I'm guessing this signal is active low, so it should be this value)
I checked all of the voltage regulators and they all output around 5 volts (at least 4.95V)
I checked the sockets by doing a continuity test between the pins of the chips and the pins of the sockets soldered to the board.
I took out the 6522 chip and did not get a display, so I'm assuming that it is okay.
I took out both 6520 chips and it does the same thing, so I'm guessing that one or both may be bad.
My only other guess is a bad ROM chip.
7167 BYTES FREE
READY.
Motor - 2.3 volts
