NathanAllan
I am trying to get this machine marked good or bad. The setup I have is as follows:
Altos 986T
serial ports 1-7, db25
hdd expansion port, large db
altos net 1, db15
IBM 486 Executive tower
serial ports 1 and 2, db9
null modem/laplink cable, db9-db25 by manhattan cables
I fired up terminal and told it to go 9600bps, on comm1, stop bit 1, got nothing; hooked up to serial1 on the Altos.
What am I doing wrong? The Altos makes the spinning up noise, the fdd and hdd both make sounds, and no beep codes are heard. terminal isn't telling me anything. I intend to hook up to the win95 laptop with hyperterminal next (more control).
This all happened after I went in a bunch of boxes searching for ANY term program, finally hooked up that IBM. The frustration comes with the hobby, I guess!
Nathan
Altos 986T
altos net 1, db15
Nathan
