Fox W.
Hey all, so far I've restore the PSU and the screen. The issue I'm having is trying to make CF storage work.
I'm using the typical Syba SD-CF-IDE unit, with a 2GB CF. I'm able to get the configuration utility part of Softpaq 'sp1855' to see it.. it shows it as a custom defined, 2GB, so LBA works.
However when booting, the system still throws the error "disk does not support block mode." I'm not sure if there is a newer firmware needed to match what the config utility can do, or what. It's really hard to find much support for these since they are uncommon.
Has anyone succeeded in using CF storage on these?
Thanks!
Thanks!
