Compaq Portable II NEC D3142 Disk Error
Swift1776
Hi!, I just purchased a Compaq Portable II and it boots from drive A>. However, I can’t boot from the HDD. I get a 1790-Disk 0 Error.
I used an IBM AT Diagnostics Disk to set the bios and it seems to a cost my changes. I set the HDD Disk Type to 13 for the NEC D3142 disk drive installed. A type 13 was the closest match.
Anyone have any ideas?
Thanks you,
Howard
T-R-A
Western NC
You need the Compaq Softpaq for that model, not an IBM disk. If memory serves, it's SP0306 (Google for it).
Swift1776
It’s a NEC D3142
Data Heads 8
Data Surfaces 8
Tracks/Surface 642
Track Density 850 tpi
Bit Density 14,000 bpi
Sectors/Track 17 (RLL = 26 sectors)
Bytes/Sector 512
Record Method MFM
T-R-A
Western NC
It’s a NEC D3142
Data Heads 8
Data Surfaces 8
Tracks/Surface 642
Bytes/Sector 512
Record Method MFM
So does any drive in the softpaq setup show those parameters? You can also use ROMTABLE.EXE (from the below link) ran from a floppy to see the list of supported drives:
http://mpolibbs.steptail.com/drivers_1/APU/SEKALAIS/
