Chuckster_in_Jax
Are you checking the motherboard or the power supply. I don't see any device listed as CB3 or CB4. Check the pins on the motherboard where the power supply connects. There are four voltages supplied. The service manual shows what voltages should be present as well as the proper ground for each. Put your meter across these pins and see if you get a low resistance. Keep in mind that any capacitor that is connected across the supply voltage could be shorted an it is difficult to determine which one is bad. The ones I found to be bad were the tantalums very close to the power connection on the motherboard. The schematic shows those to be located at I27, J27 and K27 on the gridtrace pages 12 and 41 in the service manual.
I've got commitments all day, so it will be late tonight or tomorrow for me to reply again.
