Compaq Presario 4505 Restore Disks
Lutiana
Administrator
Staff member
Dublin, CA USA
Anyone got them? Or have a line on them? I bought one of these machines at a thrift store and I want to restore it to factory settings.
Thanks @Plasma - Neither of those are for this model, though they may work with some tweaks (I plan to try them both). I was hoping to find the actual CDs.
I've ben down this rabbit hole and found this https://h10032.www1.hp.com/ctg/Manual/bpb12296.pdf (which is mirrored here on the Retroweb.)
Basically the entire series looks to have used the same motherboard, but with different options on CPU, RAM, Video RAM and cache (for example the 4505 shipped with no cache, 16Mb of RAM, 1Mb VRAM and a P166, the 4528 on the other hand shipped with 256kb of Cache, 32Mb of RAM, 1Mb VRAM and a P233). The board appears to be this one on the Retroweb.
There are two recovery sets available on Archive.org:
Those BN numbers are important as this is what the restore CDs us to identify the system being restored, and is referred to as the "Configuration Code" for the various models. The serial numbers for these units are in the format of:
1234BNxxA567
where BNxx is the identifier (see the PDF linked above for a reference table of the various configuration codes).
So to get either of these restore options to work, you simply enter the machine's serial number, but change the numbers after the BN to an appropriate number that works with the recovery media (2A, 52 or 28).
And lastly for anyone who wants to know how I worked out what media works with what model identifiers, that is pretty easy. It's in the \MAP\BOMID.TXT file in the ISO.
I am mostly posting this here for posterity, and because this may also apply to other such Compaq series of machines of the time.
(Thanks to the people at Vogons for some help on this as well, the post is here).
