smeezekitty
So I just purchased a compuadd 433 486 machine. It is built very heavy and looks brand new inside.
It has a 3.5/5.25 inch combination floppy drive but it will not boot from it.
During POST, both halves seek and flash their light but then it says "No boot device available - strike F1 to retry boot, F2 for setup utility" (this is with a 3.5 inch dos boot disk in)
Pressing F1 makes the 5 inch ONLY floppy flash its light and then it says the same message.
Inserting a blank 5.25 inch floppy makes it say "Diskette read failure instead"
In case it matters, there is some type of tape drive also attached to the floopy connector.
Can someone please help? It would be appreciated!
