A few pointers for when you decide to get this system running:
As pointed out above, the PCVideo board is designed for use with a PC/XT keyboard and your choice of a CGA or MDA display. You can use a more common PS/2 keyboard with it by using an adapter like this one:
Use PS/2 (or AT with passive adapter see related products below ) keyboards on PC and XT systems such as IBM 5150 and 5160.
monotech.fwscart.com
... and an MDA/CGA to VGA adapter like this one:
Note: Semiconductor shortage is greatly delaying the production of new stock. It may be a few months or over a year away. New and improved, smaller version! Convert MDA, Hercules, CGA, and EGA video signals to VGA for use with a modern monitor. Run your vintage PCs with their native video cards...
CompuPro's boot disks for systems of this vintage were all on 8" floppy disks. Boot disk image files for CompuPro's systems are readily available from several software repositories on the web. If you don't have real 8" drives, a Gotek device emulating an 8" drive, connected to CompuPro's 8" floppy drive controller port via a 50-to-34 pin adapter, works fine.
Your system can run any version of CompuPro CP/M 2.2, with the console on a serial terminal connected to the "System Support 1" board.
You will get more out of your system configuration using CompuPro CP/M 8-16. Later versions of CompuPro's CP/M 8-16 were able to use the PCVideo board as the console, and could run both CP/M-80 and CP/M-86 applications on the same system.
Better still, your system hardware (with the 256K of memory provided by the RAM22, and the CPU85/88) is capable of running CompuPro Concurrent DOS 8-16 up to version 4. That operating system could run CP/M-80, CP/M-86, and "well behaved" early MSDOS applications.
